On my 2012 RTS the antenna broke off at the base and the rubber plug also came off. Can I just put the antenna back on or do I need new parts? Looks like the fiberglass just snaped off at the base.
Jim
Jim
Radio reception is great!irv.--toms, yes, I do have part #'s for the short antenna and the Antenna base.deanna, do you have part #'s ? thank you.--irv toms:bowdown:
rubber ducky from Walmart works good $9
Jim[/QU
Mine did the same thing 3 years ago, I get better reception now than ever!!!!!!!!!!!! I just glued a piece of the fiberglass wanf to the rubber boot and put the boot back on. There is no connection now between the fiberglass wand and the base byt the base is still OK!!!
- :yes:
Here is the part # for the antenna base RH: 708300156
and the part # for the short antenna : 710005084.
You are welcome!
Deanna
Check with the vendors on this site, for a cover for the ignition switch hole.looking at the pic of your dash made me wonder if anyone makes a cover
for the ignition switch hole to cover when the key is out or raining or
a bunch of other reasons. they seem to make every thing else.
iv toms
