Desert Spyder
Good question. I am curious how many of you do not wear a helmet when you wear the other gear?
Hello
A question about protective gear.
Do you find you wear less, more or same protective gear when riding your Spyder than you would riding a two-wheel motorcycle because you feel you are less likely to drop the bike?
Thanks
JBIM
Not sure if you're saying this was on a Spyder or what....If your reason for wearing protective gear is for dropping the bike, on 3 wheels you will not drop. I have only gotten the spyder on 2 wheels only once. Knowing what that took to do, probably won't happen again accept in accident avoidance under extreme severe circumstance you would probably flip doing a 90 degree turn at speed.
However I ride ;
100% with a helmet and attached chin guard
100% with gloves
100% with protective shoes boots
85% with armor in jackets. (BRP makes the best) for summer and winter!
100% with jeans,
on long cold trips leather chaps over jeans
I was broadsided in 2011 in a parking lot going 12 mph, still flew 20-25 feet.
I consider each ride each time with how much I am willing to risk. Locally on a warm day I ride with less jacket protection, yet defensive riding concentration will be at 110%
I find that I am wearing less of the heavy duty gear ie: leather or knee / elbow pads etc and what I do wear is mainly for protection from the sun &/or elements. In my mind, if you fall off one of these machines, then something pretty bad has happened and all the ATGATT isn't gonna do much protecting.
......... was likely going too fast to make the curve, left the road at the peak of the curve and hit a boulder. Probably going 15-20 when he hit the boulder. Passenger was ejected from the spyder slid across the roadway and stopped about 10 meters from the Spyder.........Point is in this relatively low speed accident not being hit by another vehicle there were severe consequences that would likely have been devastating if not for ATGATT.
Yes it was on my Spyder, around 9K+ in damages, and without the spyder for 3 months. No problems since because of accident, they put back together correctly.
got new chrome wheels though!
here was the thread I created about the incident, http://www.spyderlovers.com/forums/showthread.php?34830-Broadsided All the pictures are gone ...
I did exaggerate the distance now,(original said 15-20 ft) In 5 years I will probably say something like 30-40 feet![]()
WHERE you ride makes a big difference. You don't have a location in your profile.
Temperature and weather factor in.Ontario, Canada. Why would you say that?
