Dave, I also have a 2014RTS-SE6, and replaced my long antenna ( I broke mine, putting on my 1/2 cover)and replaced it with a short antenna( part # 710005084) I bought mine from Pitbull ( Springfield, MO) and I got 2 extra base antenna boots( part # 708300156).2014RT
Taking cover off mama's RT and broke the right side anntenna. Best place $$$ to order a new one? How do I put it on? Thanks in advance
dave
Call Harvey. He has a nice antenna.
If it broke off close enough, use a socket to remove the base. Thread on the new one with a drop of blue locktite. Replace the rubber cover.
If it broke a bit high for the socket, clip it off short, then remove.
If you get in trouble, call. Joe
7 mm socket that is!Call Harvey. He has a nice antenna.
I bought a antenna from Spyderpops. Wanted to go shorter so that placing cover on would be easier. I can't seem to be able to get the factory antenna off. Obviously there isn't wrong with original antenna so I don't want to bring antenna off just so I can use a socket for more leverage so anyone have a suggestion on how to get old one off.opcorn:
