FIRST LIMP HOME TODAY
Hi I got my first limp home today and pulled the code it says PO340 but I don`t see a match in the code search any ideas what it is
thanks in advance. I have a 2014 RTS SE6
Leon
from spydercodes:
P0340,
ECM ,Crankshaft position sensor(CPS).
Damaged CPS damaged or disconnected wires ECM output pins.
Make sure sensor connector is fully inserted
Measure voltage between harness connector: CAPS-PIN 3 & ground
(expected value 11 to 13 VDC).
Measure resistance from connector: ECM A-E2 to (CPS) CAPS-2
(expected value <2 Ω).
Measure resistance from connector: ECM A-D4 to CAPS-1
from spydercodes:
P0340,
thank you sir
Leon
There you have it....
From the Alpacas mouth...:roflblack: good reason to down load the spyder codes app and carry it with you. More than likely it will clear. Have not seen many of those and may be a glitch. If after you park it remove the key and give it an hour computers will store the codes and you can ryde on. If not or it returns then head to the dealer....
Give it an Hr.
Why should it take a CPU one hr. to reset it self? Is it the same reason you need to walk 100ft from the Spyder to reset the key code.
Allenr
