frunk issue
krafael5
Help. My 14 rts frunk does not close gently. I sometimes have to close it several times by tapping the frunk hard onto the latch. Am i doing something wrong or is it a loose latch?
First thing that I would check is that the frunk gasket is aligned and seated properly. I have had the same problem twice, & it was misalignment/seating of the gasket.
my wife had the same problem
try wiggling your key. On hers, she heard a click then the frunk would close and latch properly.
Little checking..!!
make sure the pin and lock line up and are tight. As mentioned if the gasket is off it will miss-align the latch. Your having to push the pin over to catch. Not much else involved there....:thumbup:
Happens to me all the darn time
It's in the key frunk/seat release mechanism. Gently pop the seat and then remove the key. Then both the frunk and seat should close easily. Problem is the frunk release is out of adjustment. :mad: :banghead: :gaah: Popping the seat open and removing the key should center the mechanism so both should close easily........maybe. It works for me.........most of the time anyway. :thumbup: Good luck. :pray:
All advice above is on the money. An easy fix, but an annoying thing to happen. :thumbup:
frunk
Thanks everybody for your help. I will definitely try all the advice given. Again, thanks for your time.
