Gas guage indicator
Fonz
I have an 2011 RT Limited. Has anybody had trouble with the gas guage needle fluctuating up & down. Can't be sure how much gas I really have while traveling.
Yup. Welcome to the world of the analog gauge. You'll find MANY posts about it. I'm a 2010. I disconnected both the fuel and temp gauges like most have and the readings switch to the screen where speed and other things appear. MUCHO better. It is really a 10-15min job.
Sent from my iPhone7 using Tapatalk
As Phil said this happens to a lot of the RTs and as I understand it also happens to a lot of other motorcycles too. I would suggest that you have your dealer replace it even if you plan to disconnect them and use the digital gauges just so that the factory knows about the problem. I've had 3 gauges fail and I finally disconnected them and I really like the digital gauges better.
:welcome: I have had two gas gauges replaced on the 2010 RTS--and the 2nd one is doing the same.
welcome to the club
As Phil said, this is unfortunately a common problem on most RTs. Like many, we disconnected our analogue gauges & they both show up now on the center LCD screen & they both seem much more stable & accurate. If you'd like to do it also, its easy. Just remove the 4 bolts that hold the dash bezel in place, disconnect both wire sets to the analogue gauges, push the loose wires back into the dash area & replace your dash bezel with the 4 bolts. Once you turn the Spyder back on, your fuel will show up on the right side of the LCD screen & it toggles with your audio volume control. Your temp. gauge will show on the left side of the LCD display & it toggles with the push button rear suspension control.
I personally like the digital read-outs better & it gave me room to add the cup-holder & LCD rear-view camera system to keep an eye on Teddy.
Granted, BRP has some work to do on this issue & I do believe they actually have a next-gen gauge replacement out, tho I'd think they'd have them on newer units from the factory, but what do I know:lecturef_smilie: Hope u find a suitable solution that works for you.
Thanks for your help, disconnected the guage and everything is working fine. Hope I responded in the right way. I'm new new at responding
