It's Heeeeerrrrrrreeeeeeeee!!!!!!! Navigation!
I posted a one star review of the BRP GO! and got a response from the developers and ordered a 6 inch cable this morning...
Quote
: We recommend a USB 2.0 or higher cable supporting 3 amps or more, a data transfer speed of at least 480 Mbps, and 6 inches long or less. Also ensure the following permissions have been enabled in your phone’s settings:
- Appear on top (Settings > Apps > BRP GO! > Appear on top > On)
- Nearby devices & Phone (Settings > Apps > BRP GO! > Permissions)
Quote: We recommend a USB 2.0 or higher cable supporting 3 amps or more, a data transfer speed of at least 480 Mbps, and 6 inches long or less. Also ensure the following permissions have been enabled in your phone’s settings:
thanks for the tip, ordered a 2 pack of the ones you said to,supposed to be here friday, hope they work...🤞
I use a 1 meter/3.3 foot long USB-A to USB-C cable from Belkin. I choose that cable because it has a heavy braided sheath over the cable, protecting it from anything it might rub on while riding. It's worked fine with Apple CarPlay.
I downloaded the update, everything went smoothly, but it shows a picture of the '23 that I had, the F3 base model. It said I can use navigation but it wouldn't show on the screen. l have the 10.25 screen, don't quite know how to figure it out, so I'm going to take it to the dealership tomorrow and ask them. They're not open today, hopefully it doesn't rain.🤞
You might need to go to Preferences and Navigation to select BRP Go! instead of CarPlay for the default navigation system. It has to be connect to your phone by USB so make sure you have a USB data cable not just a charging cable.
I suspect after playing with the BRP Go! navigation on the Spyder you'll go back to paper maps.
Well, it does work with the new short cable that was delivered this evening.
The wife and I went to a gas station that a search with it provided from our home 40. I quickly found out I needed to change the display back to a white background to see navigation. I can see this navigation via BRP-Go! being of use maybe sometime... Not really worth messing with as I already have a decent GPS on the bike.
Get a large rubber band and strap it to the cubby hole door I guess.
