Loose screws in RTS dash
cognaccruiser
Just a little heads up. This week while out riding I noticed that one of the 4 screws in my dash was just sitting there in the little depression. Lucky that it didn't go awol. There was no real reason for it to be loose. I have never taken the dash off so it just seems to have loosened on its own. I checked the other 3 screws and each one was a tiny bit loose and could be snugged up without any effort. Might want to check them periodically rather than lose one.
Gary
I have now encountered the same situation a couple times. Another item added to the inspection list for me. :thumbup:
Ok when people run out of spyder topics and start threads about loose screws, its time to start talkin polaticsnojoke
...or oil
...or tires
Mine are all replacements - not because they came loose, but because I removed them once, and one disappeared down a black hole by the handlebars! - I bought four new ones because I couldn't find a replacement with the same style head. :banghead:
I had the same thing happen on my 2014 RT.
Last year I had the lower left screw come out and lay in the pocket until I could stop and put it back In and tighten.
Loose screws
Me too. I carry a 7 piece tamper proof Torx set (it's like a folding pocket knife) in the frunk. Harbor Freight has them for $6.00. Item no 97471. A little drop of nail polish on the threads will help. Do not use Lock Tite.
...or oil
...or tires
Naw! I think there are a lot of loose screws around here. :roflblack::roflblack:
Snug
Going go go snug them up now---- maybe a dab of RTV?????
Loose and lost screws cause:::
Kaos
Loose screws can cause Kaos
WELL-------- they were all very " un tight".
I suggest we all check them. There is a brass embedded nut in plasstic so be careful tightening them. Maybe 8 or 10 INCH pounds at most.
Kaos
