Habib
Since I want to be as Spyder correct as possible I purchased a BRB oil change kit from the dealer to do my first change with. It's got a blended oil not pure synthetic. I will be using a pure syn in the future but is the blended what BRP is supplying from the factory? I also read where it takes a shade under 6 quarts to change oil and filter in the 1330, there is only 5 quarts in the 'kit'. Will I have to go back to the dealer for another quart of blended oil to top it off with or can I use another JASO M or M2 oil to top it off and can I top it off with a pure syn or do I need blended?
My Baja Ron filter and 6 quarts of Valvoline motorcycle JASO M2 oil from Autozone is a hell of a lot less expensive than what BRP want's They don't even print on the oil what specifications it meets that info is only in the manual.
