spacetiger
I am hoping someone could give me some suggestions. My dealer installed my quick connect for my battery tender in the frunk area of my 2013 ST Limited. I am concerned that if I leave the frunk open, mice will get in and chew or make nests in my Spyder. If I close the frunk on the cord, I worry that it won't be good for the cord or the seal of the frunk. Is there anything that any of you do to keep mice away when storing your Spyders?
Take a look at your wheel wells. They are wide open and lead back into the engine compartment; all under the bodywork. If you do have a mice problem, you need to find a way to deal with it here. Your frunk is the least of your problems as the mice are more likely to go inside the bodywork where they can build a nest hidden away. The frunk is just a big hole with no place to hide.
I say put some old fashion mice traps with PP under the bike. 2-3 should do. Any mouse that gets snagged will serve as warning to the others that come near the Spyder...
Jerry
