ulflyer
Well-known member
Thinking about a trailer and see that most of them are the common flat 4 wire. Other than that, I have no idea what is involved in wiring the RT to accomodate a trailer. For example, any place that sells trailer accessories sell wiring harnesses that work with the flat 4 wire on a trailer. Can these be wired into the RT harness somewhere? Or is there a special harness that only works with the RT? If some of you could give me an idea I'd apprec it.
If I get past the wiring, I'd prob go with the Canadian hitch that runs about $250. Theres a couple of trailers locally that I'd want to look at that doesn't cost an arm and leg as this is not something that I'd use a lot.
