Where do most people mount their Gremlin Bells on their Spyders?
Elembytes
Just curious where most of you mount your Gremlin Bells? I got one gifted to me recently and want a good location to put it and was wondering where others put it and what you are using to mount it with.
Thank you!
Let's see....
According to the ledgend, you need to mount it at the lowest point cause the gremlins come up from the road. you need to catch them before they can attach themselves to your machine...Mine is on the lower A arm shroud key ringed through a small hole. many go for the foot peg...:thumbup:
attachment.php
On my RT IO hung it from the steel loop at the bottom of the brake lever.
AJ
Thank you!
I have two, one under each passenger footboard. Drilled a hole through one of the vanes under each of the footboards and used a large key ring to attach them.
According to the Legend: they should be hung low on the bike...
But I opted for convenience, and went for a pair of them on the license plate bracket.
attachment.php
Mounted my to the brake pedalwith a key ring. I then coated the key ring with liquid lectric to prevent the ring from rusting.
I have four gremlin bells that people have given me, one under each floorboard and one zip tied to each A-arm. To attach under the floorboards, I popped off the rubber mats, drilled a 1/4 inch hole, and fixed an inverted eyebolt to which the bells are attached.
Pam
attachment.php
attachment.php
Here is where I have mine on a 2014RTS-SE6:
attachment.php
on grill ( left side) near the drivers floor board.
Attached with a piece of wire. Deanna
