Rednaxs60
Another thread that relates to this one regarding BajaRon's sway bar from a few years back: https://www.spyderlovers.com/forums/showthread.php?84363-Baja-Ron-Sway-Bar-Regrets
For anyone interested..... Installed the upgraded swaybar. It accomplished exactly what Pierre said in the video. My 2020 RTL is most definitely planted better in the curves. It is worth the money, at least to me.
Wow! A lot of very knowledgeable people here!
Two observations:
1. Each of us has different expectations and different requirements for our suspensions. For instance, mine is comfort and stability on freeways and surface streets as a single 180lbs rider with at most 50lbs tools and materials, occasionally towing a trailer at 55mph (well maybe 65mph). For the twisties I take the Royal Enfield.
2. The extreme lay-down angle and chassis-to-wheel distance of the front shocks concerns me regarding analogies to traditional (ie, more upright) shock positioning and associated sway bar performance. There's increased stiction and shaft side-loading; increased leverage on A-arm bushings; and then the chassis-to-wheel length of the A-arms themselves.
My expectations and analysis are leading me down this path: tires (done); bushings (in hand); shocks (ordered); tighten and maybe replace handlebar-to-DPS links; laser alignment (if available locally); and maybe re-install OEM sway bar.
And I'm watching with fascination how the rest of you are achieving your expectations and requirements.
BR -- I intend to replace the 8 bushings at the chassis end of the A-arms with BRP 706201519, assuming I can press the old ones out. Why? It's just something I've always done to my car suspensions so when I saw the Spyder front-end my old habit kicked in. I checked to see if Energy Suspension had any pieces that would fit -- no joy -- didn't check Prothane.
One thing that's out of my experience is all my cars have been MacPherson strut front-ends. And the only experience I have with integrated coil-damper "laydown" suspension is motorcycle front-ends. So I'm kinda feeling my way here. I understand the tradeoffs the BRP engineers made. I'm just not sure how to modify them to my preferences so proceeding based on past car and motorcycle experiences. And careful reading of your, PMK, rednaxs60, et al posts.
New 2020RT(leftover) having Spyder Pops put on BajaRon Swaybar & links this Tuesday. To me at 70+mph on a sweeper curve bike is too twitchy.
Will test out in Arkansas twistie roads this week.
Hope it helps.
