ChasingWind
All the sudden my drive belt was off the back sprocket - tried for a week to get it aligned - it would either go way in and rub against the motor or hang off a 1/4 inch -- and then I noticed the belt started to loose teeth
after pulling belt noticed motor drive sprocket wobbling all over the place - the splines on he drive sprocket where toast - luckily the splines on the drive shaft are ok -
So if your belt all the sudden goes out of alignment make sure to check the front drive sprocket for play - my is an 08 with 38000 plus miles on her.
Just passing on info
