Digital display affected by heat
agedbikeman
Where I live in the north of France, this week the temperature has soared into the 30's, unusual for here, however I left my RT in the sunshine, when I switched on the digital display had 2 black bands top and bottom, as the display cooled down they disappeared, I know LCD can be affected by temperature but has anyone else had this problem.
Alex
A common occurrence when the temperature gets higher and the :ani29: is left out in the sun.
shade.
I put my driving gloves over the display. You have to put them some place. Stops the lines. Ride on...
:riding:
Hi SPECTACUALR SPIDERMAN,
Re: When you say 30's you do mean celsius?
30*C = 86*F
Jerry Baumchen
PS) And that is quite warm for northern France.
Some folks will pull out the "warning card", for use as a shade for the display... :thumbup:
That's exactly what I did, I also pegged a duster to it for extra insulation.:doorag:
SO!! there is a sensible use for the "warning card", I have removed the sticker, didn't want other bikers to see it and think I was some sort of an idiot that needed to read such rubbish before I ride, after all if you need to read the warning card you shouln't even be let loose on roller skates let alone a motorbike!!!!!!!!!!!!!!:ohyea:
I think I will print a label saying screen protector to cover up the words "Warning Card".
How to turn a piece of useless kit into a FARKLE:clap::clap::clap::yes:
Happens.....
As mentioned, pulling the safety card down is a quick easy way to prevent this. I also do it when the sun is to my back on long straight roads. Now if you have a pull over cover it will be even better to keep the seat cool and people off. :thumbup:
I have this happen at least 25 times this summer on 90+ days. I'm glad this tread was started, because I never thought of pulling the safety card down to protect it. Great tip.
I've seen this on $3k+ 2 way radios in direct sunlight for extended periods do this as well.
Arizona Hot
I have a 2013 RTS and regularly ride in over 100 in the summer and have had a few rides in over 110 and never had the display problem. But we have a dry heat, maybe it is a temp/humidity problem.
agedbikerman: "If I wasn't so cleverI wouldn't need to be so good looking."
:roflblack::roflblack::roflblack:
If you'd like to alternate that line occasionally, here's another one: "I'm not conceited; conceit is a fault, and I don't have any faults." :thumbup:
And if you like the spirits: "I'd rather have a bottle in front o' me than a frontal lobotomy." :yikes:
Alex
Had the exact same issue this spring while in South Carolina and Georgia. Temps in high 90's. You description is exactly what happened to mine. I thought I was going to have problems with the bike while out for the next week and half. Temps drop display comes back to normal.
Willie
