DPS issues on a 2012 RT?
ulflyer
Well-known member
A friend just called from work; her RT SE is showing the DPS as faulty and she's worried about getting home on it this evening after work. No dealer nearby. If it runs ok, is is safe to ride it home?
There shouldn't be any problem with driving it home. The steering won't be quite as easy. I rode my '09 for a few thousand miles without it working, JMO
For peace of mind I would reseat the fuses/relays in the box under the trunk lid (front). Then, check to see if the dps lite is still lit. If the light is still lit and she is concerned to the point of not giving full attention to the road/drivers, she may want to consider having someone else drive it or flat bedded to her dealer. JMO
Call BRP hotline.
As long as they feel comfortable they should be fine to drive home. As stated they wouldn't have the assisted steering. I would probably stay any highways in case the unit enters limp mode.
