Front end shaking around 55 mph - anyone else have this issue?
The 3 things that I would look at first, 1.) tires (how old are they, what the thread wear looks like, air pressure even between the two front tires). 2.) rotors (are they worn or look warped when you rotate them). 3.) front end alignment (try and get your fount end laser aligned).
I would also look at tire balance issue. Mine did the same thing when I replaced the fronts and used Ride-on to balance. First time out did this for about .25 miles but came out of it and now smooth as silk.
