How do I get that Map in the Signature Block???
Do you see forum rules on the left hand side? Now go to the right until you see Visited states Map. Just click on that and fill in the states you've visited.
Where can I get a map that highlights the states I've riden in? I see it in a lot of memeber's signature blocks.
Ours is a bit different because we’ve roamed farther afield than most. Had to combine two countries and do some photoshopping.
Try this airmen 2090, after you created your map I saw on the lower right an "add to signature" or something to that affect and clicked it. If my signature line shows the map on this post it should work for you too. I must have missed it before also.
Don't forget to click on add to signature line. I had to go back and click on it and now the map shows.
States and Provinces of Canada.
There isn't a default map available for that, but you can always add something (within reason & complying with the Forum Rules) to your sig line. ;)
You'll need to find a map that suits/shows what you want; do some photo-shop work to highlight the applicable States/Provinces; and then add the resulting image to your sig line. But please do keep it small - not too long &/or too wide. Remember that not all members here users have access to &/or always use a large screen device, and if you make your sig line content too large for others to readily to display without scrolling or otherwise manipulating their screen every time they try to look at one of your posts, it'll probably prompt some complaints, and that could well lead to some mandatory changes... :lecturef_smilie:
