Wildchild6969
I have a 2008 GS. It does have the LED lights on the fender.
I just got the bike last week and was on a ride with some freinds when it was noticed that a wire was hanging down inside the left fender. At this point everything was working fine. Wasn't much I could do at the time so I rode it on home. By the time I got home none of the lights on the left fender was working. I took off the wheel and found the same wire from earlier had rubbed against the tire enough to wear all the insulation off of them so I figured I would patch them up and change a fuse. No such luck. After patching the wires and testing every fuse in the box they still aren't working. All other lights on the bike are fine it's just the left fender. I followed the wire harness to the end of the a-arm up next to the engine, and unplugged it. I then applied 12 volts to the harness and the fender lights all came on so I know the lights themselves work and my earlier patching up of the wires was successful. Is there something I'm missing here? Relay or additional fuses? Please help if you can. Thanks!
