NHTSA Campaign 26V575000 - 2025-2026 Spyder RT, F3, & Canyon freezing cluster fix issued
Unfortunately my 2.5 Ghz broadband doesn't work well in the garage. No matter, we took both our S2S's (23+24) in to Extreme Propulsion in Cartersville GA for oil changes plus the new update on my 2024 screen. Also had them do a full check on both for the air bag rear suspension. Also, mine needed the steering angle sensor adjusted post the alignment that they had previously performed. BTW they are one of the premier dealerships in the Southeast... handle the full line of BRP EXCEPT snow mobiles! HAHA. The Spyder tech is very good... Ask for AJ if you want to get your RT serviced. He is really good.:)
Both Spyders are all good now and my screen def shows the 4.0.1 update, B4 I erred in looking... CSS isn't the screen firmware (what I had previously posted... my bad!)
I also ordered the Lamonster Ram mount with 1" ball that mounts using the 2 bolts on the center of the handlebars, along with a phone mount and short clamp so that we can have 2 Spyders with Maps running. On my 2024, I only connect the phone to my Sena 50S helmet set, nothing else. This to avoid any issues with the BT/USB memory crashes/freezes that stupid screen has suffered from Day1. I have been told that it is fixed now, but I still am not trusting Can-Am to have done a good job of that.
