Proper orientation of photos method - test
Bamajohn
Well-known member
This is a test to check out a method for proper orientation of photos.
Photo on right - taken with iPhone 11, holding phone vertical (portrait mode).
Photo in the middle - photo taken with iPhone 11, tilting phone top to the left 90 degrees.
Photo on the left - photo taken with same phone, vertical (portrait mode), but I opened the photo and rotated it 360 degrees; saved it, and it posted in proper orientation.
I've been doing the 3rd option on all photos posted over the past 6-8 months and it works every time.
PLEASE NOTE: I'm not trying to usurp Peter's instructions, just offering this as a point of interest.
Thank you for this John. I think our Spyders are supposed to be delivered to the house later today. Maybe I’ll try your suggestion and give posting photos another try. ;)
That room/place is beautiful! I’d love a cabin type house.
Thanks. I took those photos early morning without much lighting, just for the test, so they're pretty crude.
The Treehouse is a comfortable log home of modest size. It can't be seen from the street in summer and I can't see another house (but others are nearby).
Photo on right-- taken with iPhone 11, holding phone vertical (portrait mode).
Photo in the middle--photo taken with iPhone 11, tilting phone top to the left 90 degrees.
Photo on the left--photo taken with same phone, vertical (portrait mode)..but I opened the photo and rotated it 360 degrees; saved it, and it posted in proper orientation.
I don't think anything you've done/shown there ^ is at odds with what I've been telling people for ages (except that you haven'tquite finished the job of inserting them as thumbnails, cos you can see they are still only 'Attachments' and the filename); in fact, if you look back at some of my earlier posts on the subject, I believe that there is more than one post back there where I suggest using a photo-editor to re-assign the 'Anchor Point', which is effectively what you've done in your 3rd option. ;)
But I think it's pretty clear from your post showing those pics - with:
  • Your pic on the right, taken with the phone in Portrait mode & displaying the pic sideways; followed by;
  • Your pic in the middle, taken by rotating the phone counter-clockwise 90°, turning it to Landscape mode, & then displaying the pic in the correct orientation;
that as I've been saying in my 'shorter version' posts on how to do this -
the SIMPLEST METHOD of getting your pics to display in the correct orientation every time is to simply take them in Landscape mode as suggested, then upload them -​
that way, they'll display correctly, every time! :ohyea:
So there clearly ARE other methods that work to achieve the correct orientation/display of pics, you've shown one that works above, a method that I've made mention of previously, but all of the other methods (that I can think of anyway! :p ) involve more action/more steps than simply taking the pic in Landscape mode as suggested. Still, if anyone is trying to post up an image that they DIDN'T originally take in Landscape mode for whatever reason, opening it in an editor or other software and then, as you've done, doing whatever is necessary to re-assign the Anchor Point to the top left corner of the orientation that you want it to appear in is one way of getting the job done! So thanks for showing that clearly! 👍
Test
Second test
Third test
Fourth Test
I can not figure out why you say my attached photos are attached wrong. I followed the directions as posted.
But, unlike the last couple of pics you posted BEFORE those up there, none of those pics ^ are 'attached wrong'! Here, you've managed to properly upload them; attach them; AND you've then gone on to insert them as thumbnails!! :love:
However, if you look at the pics in the very first post in this thread, can you see the word 'Attachment' above them, and the file name that appears at the bottom of each?? THAT shows me that those particular images in post #1 HAVE NOT been inserted as thumbnails, they've had steps 1. & 2. completed, then stopped; instead of finishing by doing steps 3. 4. & 5. in the listed directions - shown here:
  1. locating your cursor in the text where you want to position the image/attachment in your post;
  2. clicking on the attachment so that it shows 'Insert' emblazoned across the top;
  3. clicking on the word 'Insert' which appears across the top of the small image showing in the 'Attach Files' box below the text entry field of the new post/edit post; and
  4. then selecting 'Thumbnail' (which is the the top of the 2 options that will appear when you click on the image above) in order to complete uploading the attachment as a thumbnail before;
  5. (re)submitting the post by pressing ('Save')/'Post reply'!!
Now admittedly, when BamaJohn originally posted those pics, he was playing with picture orientation, and he was doing it on the old platform, so it was a little harder to finish the job and insert pics as thumbnails back then; but on this new platform, it's a whole lot easier, and it's easier to see when people haven't done the right thing, because if you (or anyone) can still see the word 'Attachment' above the pics in anyone's post, and you can see the file name at the bottom of each pic, then it's quite clear at a glance that, just like the pics in post #1 above, and those last couple of pics I fixed for you earlier, Snoking, the last 3 'clicks' in the listed directions above, ie. #'s 3. 4. & 5. above just haven't been done!! You got close, did the uploading and attaching, but you didn't quite finish the job by inserting them as thumbnails... And all it would've taken for you to realise that would've been if you'd looked for and seen that word 'Attachment' above your pics once you'd posted the reply - cos if that word is there, then you know that you haven't quite finished inserting your pics as thumbnails! :cautious:
So in all of your pics in the post above, it's clear that you HAVE finished the job properly; unlike the pics that you put up a while ago in your posts in the 'Anyone in Northern Texas...' and the 'What are the required dimensions...' Threads (the Mods can all see the post history and the logs that confirm this). Only, you know what the really frustrating bit is?? It's that you seem to manage to do all of this 'Insert as thumbnails' thing fine for at least a few days; then all of sudden, you up and post another bunch of pics without finishing the job again!! o_O And it's rarely just one pic you do this to, either; it's almost always more than one, and they're usually in different threads too, so it takes even more time to sort it out & fix them, but I know I'll keep on getting the messages saying 'I can't see Snokings pics' until I do fix them! 😣 There are times that it almost feels as tho it's deliberate, but I'm hoping that you are at least trying to do the right thing! ;)
Ps: Can you see the little image with 'map.png' showing alongside it in @shannonmarie's post #2 above?? That's just one of the symbols which will be all that some readers will get to see of your pics if they haven't been uploaded, attached, and inserted as thumbnails properly; and there'll probably be more who will see images like that and won't be able to see your pics at some stage in the future if you ever change the device you use &/or your source file gets moved, or changed/corrupted on your device/whatever host site you might use; then there's a bigger symbol that might show if the image file is too large; a different message that appears if the host site has blocked sharing; and if you uploaded the full sized image but didn't attach it &/or insert it, the whole image may just disappear completely, so there might be be text in a post saying 'see the pic', only there's no pic there to see!! :oops:
We're working thru them slowly and trying to rescue any that we can, but there's a whole lot of years of posting all of this ^ (and probably more) can be seen on the Forum already, especially in the older posts where more people tended to use the 'image' link in the menu bar above the text box! Using 'Attach Files' is sooo much easier, just so long as you finish the job properly. (y)
I remain confused as I did these the same as before.
I'm sorry Snoking, but if you had done that, then the word 'Attachment' wouldn't have shown above those pics in the other threads; the file names wouldn't have shown in your submitted posts in those threads; and I wouldn't have touched them.
But it's easy enough to make sure this doesn't happen again - if you post any pics, then AFTER you've submitted the post and you can see it on the screen as you intend it to be seen by everyone else, look at it carefully - if you can still see the word 'Attachment' above the pic/s &/or the file names below them, then you HAVEN'T YET inserted them as thumbnails, so click on 'Edit' in the bottom left of your post, then in that Edit screen, starting at #1 of the listed directions above, follow the directions thru the process to #4 for each pic; and only when you can see BOTH an image in the text box on your screen, where you want them to appear in your post, AND an image in the 'Attach Files' box for each pic, with the word 'Insert' showing up in the top left of each image, a small garbage can showing in the top right of each image, and the file name down the bottom of each image, so that all the images LOOK as tho they're duplicated, only then do you move on to step #5! And as mentioned in the first sentence of this para, once you've submitted the post again, look at it carefully before moving to anywhere else on the Forum &/or your device - but if you can still see the word 'Attachment' above any of the pic/s you might think that you've inserted as thumbnails, &/or you can see the file names below them, then you HAVEN'T YET inserted them as thumbnails, so repeat the process until you can no longer see the word 'Attachment' above them or the file names in the thumbnails. ;)
