BajaRon
Well-known member
No, they just have their power band higher than where some other engines have theirs. Apples and oranges, my friend, apples and oranges.
Or maybe sour grapes and lemons.....
So in other words, the Spyder engines are way under powered?
I agree! We got short changed! The same Rotax 990 in the Aprilia makes way more HP. Engine Type V990 - Can-Am Spyder, reverse trike 95–106 hp (71–79 kW), Aprilia (RSV 1000, Tuono) 139 hp (104 kW)
I'd love a 139Hp Spyder.
But back to your comment.. compared to what? The Revolution motor in the V-Rod makes what, 126?
its strong enough to follow a bike - sometimes you need the higher RPMsSo in other words, the Spyder engines are way under powered?
I never said anything about valves knocking. Go back and read that post. The comment concerned "engine knocking" when or if using a lower octane fuel. I asked how anyone can hear the engine knock what with the loud exhaust and engine noise.
You'll eventually just 'feel' it when it's the right time to shift.
Isn't that a question or maybe there's some other symbol to use for asking a question?
Oh, and my lawn mower has a straight four cylinder engine in it and a five-speed tranny. Can't drive it on the highways, but it's still fun to use. The windshield mounts don't break, there are no gas leaks or odors, and the gas doesn't boil in the tank. The gas cap, by the way, never heats up to the point I can't remover it from the filler neck. As for the anti-sway bar, never broke a mount, and the darn thing never went into "Limp Back To The Machine Shed" mode.
Nope.So in other words, the Spyder engines are way under powered?
:agree: If you want to figure what speed that is at, glance at the speedometer. Keep in mind that it also depends on the terrain and how hard you are working the engine. Cruising along at 3,500 rpm at 35 mph in 3rd gear may be OK on a flat road with no passenger or trailer, but the engine will struggle at that rpm on hills, riding two-up, or towing. The peak performance of the Spyder engine doesn't kick in until 5,000 rpm or above. Once you experience what the engine really has to offer, you may not want to ever short shift it again. From 5K to the redline it runs very nicely!
