TricLED bumpskid LED kit; where to find harness connector?
UtahPete
Well-known member
The connection wire on this is only 24", which isn't long enough to bring it up to the harness connector for the running light at the headlight. Before I cut off the harness adapter and just use splice connectors, does anyone know where there might be a 12v line (switched) with a 2-prong harness plug close enough to the bump skid I could use it as intended? Thanks.
Pete, Can it be that TricLED screwed up that badly, or am I missing something essential? Have you contacted them to discuss your problem?
That harness is ment to plug into the connector on the a arm that feeds your fender lights.
Easy peasy it's a switched circuit.
Hope that helps you, Gary
That harness is ment to plug into the connector on the a arm that feeds your fender lights. Easy peasy it's a switched circuit. Hope that helps you, Gary
Hi Gary, yes it does. Now I just have to find that connector. Probably in toward the engine?
Under the A Arm about 6 inches from the fender on the bottom of the plastic covers for the A ARM
That's where you will find those connectors
MAy have to cut a wire tie or two to get at the connector easier
Under the A Arm about 6 inches from the fender on the bottom of the plastic covers for the A ARM That's where you will find those connectors. MAy have to cut a wire tie or two to get at the connector easier
Thanks. That's great info. I'm surprised TricLED didn't mention that in their D-I-Y instructions.
